Whirlpool MH7130XEZ2
ssruindia
Orlando
There are TWO lights inside the microwave which turns on by either opening the door or have the microwave running (heating). The light to the left is not working and the light to the right is working fine.
Question: Where can I find the part (bulb) and also the instructions to change the light. Flow Diagram etc.
You need the oven light correct? You should just have 1 that lights the inside of your microwave oven.
Not the 2 cooktop lights?
MH7130XEZ2
Diagram#5 Part location#11 is your oven light bulb you can order.
Page #47 & #48 here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use and Care Guide - 4359622.pdf
show you how to replace them.
show
-Normally- only one bulb inside, one grill is air flow and other grill has the light bulb.
