Whirlpool Microwave GMH3204XVB1 stopped heating
Mathews Man
MI
GMH3204XVB1
Greetings:
So, my microwave GMH3204XVB1 stopped heating, but all other functions are working. Everything I read online says change the magnetron. Any way to confirm this is the faulty part prior to ordering it? Thanks in advance!
Drew
Added complete model number
Hi Drew,
Your missing the last digit in your model number. That's very important to have. The model number tag should be located inside the door.
Here's the results I get:
GMH3204XVB0
GMH3204XVB1
GMH3204XVB2
GMH3204XVB3
Rick is the best at Microwaves, once you post that last digit, I'll ask him if he can assist you.
Thanks, I'll message Rick to see if he can assist you.
Start the microwave and check for 120 VAC on the Primary side of the high voltage transformer. If the voltage is correct, the problem is one of the high side components. Before checking the HV components, make sure the machine is unplugged and discharge the HV capacitor. Here's how to check the high side components:
Thanks Rick!
Drew: Let us know what you find.
