- WMH53520CW0
- Whirlpool
- 6-10 years
I'm having the open/close door error that seems to be common with these microwaves. However, my microwave seems to work at times and then at other times it gives error message and won't run. I opened up the control panel and removed both cam assemblies. I tested each individually with the door latch and they seem to work fine mechanically.
My question is, since the error happens some of the time what might the issue be? I'm trying to determine if I should replace the entire latch assembly and if so, do I replace the upper or lower latch assembly.
Corrected model number
