Whirlpool Microwave YWMH31017AS5 "door" error message
recroad
Toronto
YWMH31017AS5
I get a "door" error message when I try to start the microwave. I've tried cleaning it but that doesn't fix it. Or if it does, it's very temporary before it stops working again. When it does work it works perfect so it looks like it has to do with sensors? I've cleaned every single nook of the microwave so I think I've ruled out dirt.
Any help would be appreciated.
Recheck your model number for me. I can't get anything to come up with that one.
OK, unplug the machine and check the door interlock switches for continuity by open and closing the door. It sounds like one is not making contact or is out of adjustment. You'll need to remove the control panel to access the interlock switches.
recroad
Toronto
Thank you. Are the interlock switches/control panel the ones pictured below?
You have two interlock supports, an upper and a lower. There's a screw on top of the control panel. Remove the screw and the control panel will either lift off or open to the right like a door. From there you can access the interlock switches. One interlock switch is on the top support and two on the lower support.
