Whirlpool Microwave YWMH76718AS2 - Tries to start, shuts down immediately
immortl
USA
YWMH76718AS2
I have a Whirlpool YWMH76718AS2 microwave/convection over the range appliance. The door sensor appeared to be going out (inside light would flicker, wouldn't shut off if you opened the door and finally the "open and close door" message and it would not run at all. I replaced the lower door sensor and the door sensor message went away, the inside light only comes on when the door is open and goes off when the door is closed. However, now when I press start, the inside light comes on, there is a click behind the control panel, and then the inside light goes out and the appliance shuts off / does not start cooking, neither microwave nor convection function.
What else ought I look at? Elsewhere it was suggested trying the W11244490 sensors that are jumpered together. I'm about to order one to try, but the microwave model number doesn't appear on the bulletin.
Joe
edited to correct the model number, my bad.
immortl
USA
Thanks Rick, appreciate the help. Part was back ordered, but they checked and said it's still available from Whirlpool so it's ordered, just have to be patient. Curious if it died, or if I damaged it somehow in disconnecting the wires (some were stubborn). We'll see how it goes when the part arrives. Thanks again!
They wear out over time. I doubt you did any damage removing the wires. Keep us posted.
immortl
USA
Thanks again, and I will keep you posted. The part ought to be here in 3-4 weeks or so, maybe a tick sooner. I'll let you know how it goes.
