oregonloos
- DU1148XTPQ6
- Whirlpool
- 6-10 years
I have a Whirlpool Quiet Partner II that is about 6 years old. No complaints with the machine, it does great and I've never had any problems.
2 nights ago, 20 minutes into a cycle the machine started to emit a burning smell from the control panel area. I can only relate it to the plastic melting/ozone burning smell that happens when a computer monitor burns out.
no smoke/fire and no melted/hot/scorch marks anywhere. I pulled off the bottom panel to be sure it wasn't something in the wire harness melting but everything down there looks clean,connected and dry.
Anyhow, the cycle stopped running. I cancelled the cycle, restarted the machine and the cycle started and finished without incident.
Yesterday night, I tried to run another cycle. It sensed, started washing, released the tablet, but 20 minutes in, the cycle stopped, and the "clean" light started flashing repeatedly (7 times). I opened it up, there are no obstructions, the water is hot, everything inside looks good.
Reading up on the error - I performed the following to clear the error.
Reset breaker, pressed "heatdry normal heatdry normal cancel" open door close door. Error cleared.
Tried the cycle again in a variety of setting combinations- same thing. Exactly 20 mins in, the cycle stops and the same error occurs.
I'm thinking that something on the control board melted, or maybe the fuse blew (I didn't know it had one) I remember what burnt fuses smell like from being the kid who got sent to change them - I don't remember plastic smell.
Today I ran the diagnostic cycle - it went through fine and to my untrained eye appeared to do what it was supposed to.
Tried to run a light cycle after that and same thing happened - 20 mins in, it stopped the cycle and started flashing 7 times on the clean light.
The troubleshooting guide on the paper I pulled from below the machine says that the error is related to heater failure, but the water is getting hot so I don't know about that. Plus - the weird smell isn't inside the washer or underneath - it's only from the control panel area in the vicinity of the latch.
Could it be the fuse?
Thanks for your time and expertise.
Angela
Angela
