Whirlpool Range YWEE760H0DS0 Self clean fried oven?
Jokerstone
YWEE760H0DS0
Turned on the self clean function and it turned off half way with an error code.
Turned the self clean off.
Let it cool and went to replace the oven lightbulb which I hadn’t done for a while and when I started to unscrew, it popped and separated into two pieces, glass part and metal twist part.
fault code F6 E1 came up
I tested the oven temp sensor (can’t get the multimeter all the way in so I used wires and it showed a resistance all over the place mostly over 1000 ohms ) and the thermal fuse showed continuity.
Unplugged the stove overnight and went to plug it in now and the top element is hot to touch without any oven functions( bake, convect bake etc. Being on). When I plug in the oven I hear the oven turn on and it starts to get hot.
Whirlpool YWEE760H0DS0
Anyone know what to do? Is the control board fried? Anything else left to test and rule out?
is the control board hard to replace on this model? It’s a slide in electric
I'm attaching your tech. data sheet below, read page 10 and do what it says to do for error code F6E1
Here's the oven sensor for your model you can order if yours ohm tests bad:
W10833885 Sensor
  • Tech+Sheet+-+W10665227+-+Rev+B.pdf
Unplugged the stove over night and went to plug it in now and the top element is hot to touch without any oven functions( bake, convect bake etc. Being on).
You mean the broil element in your oven that's located on the top inside the oven?
If that's the case, then yes the oven control board has gone bad.
Here's the oven control board for your model:
Jokerstone
Awesome thanks! Yea the broil element comes on as soon as I plug in the appliance. At that price it’s not even worth it to replace. Is there something I can disconnect so that I can use the cooktop only for now?
Nope, unfortunately not.
Jokerstone
Hey Jake
should I bother running the automatic test in diagnostic mode? I’m guessing no because the broil element turns on as soon as I plug it in....thoughts?
Correct, No.
