- ET1WTKXKQ03
- Whirlpool
- More than 10 years
I have a Whirlpool refrigerator/freezer that has erratic temperatures. Sometimes the temperatures are fine, other times they go above 55F in the refrigerator compartment and above 32F in the freezer compartment. I cleaned the condenser coils on the underside of the unit and they are spotless. I also replaced the defrost timer, since I had put a mark on the timer to see if it advanced. It didn't, so that is why the timer was replaced. I set the thermostat at mid-point, and it seemed to be fine, then it became erratic. I then set it almost all the way to the coldest position, and then it seemed to work again. It even became too cold, so I set it to a warmer setting. Then it went erratic again. Seems to be OK for a week or so, then becomes erratic. I'm thinking a bad thermostat, but it's intermittent, and those problems seem to be more difficult to pinpoint. Any help would be appreciated.
Whirlpool model: ET1WTKXKQ03 Serial: ER3432039 Mfg. date: 08-04 Type: 21TFA
