linuxdummy
- GI7FVCXWY02
- Whirlpool
- 6-10 years
Adjusting the temperature makes little if any difference in the temperature. The refrigerator compartment stays in the 50s no matter what the setting is, 33 to 45. The value seems to be related to the ambient temperature, the hotter it is the warmer the refrigerator and the cooler the ambient temp the cooler the refrigerator. I've been monitoring and logging the temperature, one sensor close to the incoming air and on sensor on the middle shelf.
What I observer, no matter what the temperature is set and what the temperature is inside the damper is opened for 5 minutes once an hour. Seems that it should be open longer to maintain the proper temperature. The freezer compartment is OK. Does anyone know if opening the damper for 5 minutes once an hour is correct operation and if not any ideas as to what to check? Attached is a graph of the data starting at mid-night for today.
I'm logging the ambient temperature but it probably was around 75 degrees Fat mid-night and around 100 F probably a little above when the last open and closing the damper occurred. Note that Temp1 is the sensor positioned near the cold air output and the Temp0 sensor is laying on the middle shelf. The time between the peak before the dip and the bottom of the dip is 5 minutes always. Several days ago before we got super hot days (106 yesterday and 104 today) the shelf temperature stayed close to 51 F.
If the Temp1 sensor is placed inside the outlet vent it stays around 25F so there is cold air coming in.
