Unplug which board from the back? The LED driver board? Don't do that YET, in fact don't disconnect any wire connectors from any boards YET. READ BELOW FIRST!
Yes, Our tech bigbuck posted a service bulletin about this problem:
https://drive.google.com/open?id=1OUD3L2YYjwGY48xB2u1jH-LMZXwtUl4a
Unplug your refrigerator first, then disconnect the Pantry UI and see if everything starts working properly again. If so then unplug the refrigerator first, and check your Pantry UI wire harness first to see if you notice a short in it, if no short then the problem is the Pantry UI control board.
Here's the Pantry UI control board for your model:
CNTRL-ELEC WPW10677119 / AP6023740 made by Whirlpool
click.linksynergy.com
Look how bad the Pantry UI board was damaged here:
Hello all! Well I have some pics but cannot find where to upload them. The Pantry board WPW10677119 on my fridge is damaged so I am trying to replace the signal of the COMMUNICATION wire Yellow manually. anyone knows what is the signal sent over that wire so I can imitate it? hopefully is...
www.applianceblog.com
This should be the video to access it:
Check for any broken Pantry UI(User Interface) wires as well in the Pantry UI wire harness.
Here's the Pantry UI(User Interface) wire harness for your model:
HARNS-WIRE W11170612 / AP6284547 made by Whirlpool
Here's the video to access/replace it:
This video provides step-by-step repair instructions for replacing the pantry drawer wire harness on a KitchenAid 5 Door Refrigerator (Model KRMF706ESS01). Learn more from the experts at Repair Clinic.
www.anrdoezrs.net
