BoogaBooga
- WRF560SFYW00
- Whirlpool
- 6-10 years
Hi Everyone, I would appreciate some help here, bit of a long post.
Initially I found that the compressor would not turn on (but the condenser fan would). Per the wiring diagram the fan and compressor are on the same circuit so this mean that the starter relay or the run cap was bad. I replaced both and the compressor turns on every time the condenser fan does.
I let the fridge run overnight (albeit pretty empty) and noticed that the compressor and everything was working as usual.
The following day I noticed that the freezer was warm. I put some water bottles in there and initially they froze but the following day they started thawing.
I opened up the control board and measured the thermistors (FC, RC and EVAP)
When the fridge has been running for a ~6 hours
The evap coil got cold and eventually had a light frost to it after running for about 10 minutes
The heater was initially warm to the touch after applying power to the fridge. After a few minutes the heater turned off and the compressor and evap fan continued to run.
Anyway I am at my wits end now. I suppose the next step is the thermistors and the control board but I don't want to throw more money at it if its a sealed system issue.
Any help would be appreciated, thanks!
- EVAP thermistor was around -4F (~26.6kohm)
- RC thermistor was around 10F (~17kohm)
- FC thermistor was around 40F (~7kohm)
- EVAP thermistor was around 50F (~4.9kohm)
- RC thermistor was around 57F (~4.4kohm)
- FC thermistor was around 50F (~5.1kohm)
- The evap fan is running
- Compressor is not running
- No water in the collection tray
