wmupchurch
- WRF736SDAM14
- Whirlpool
- 1-5 years
I had an issue where the door to the fridge was somehow slightly ajar 2 nights in a row. This caused the area of the back wall of the freezer to ice over and the unit to make noise. The fridge was also not cooling properly as no air was circulating through the vents on the back wall of the fridge. Upon realizing the issue, I gently used a hair dryer to remove the ice from the vents that I could see on the back wall of the freezer. Now the fridge is fine, but the unit will not make ice. It made it twice and then stopped. The 56 test shows E5. Other test seem fine (except the water fill, which I ran twice and the second time the water spilled over, but this is my first time testing this unit so perhaps I need to run other test.
Before I remove all the stuff to get to and remove the back wall of the freezer, is there anything else I should/could test? I understand this is probably the thermister and I'll order one before I do the work to remove the back wall of the freezer, but just want to be sure that's the only item I'll need. In other words, there may still be some ice there and perhaps getting rid of that would fix it, but if I'm going to do all the work to get there, I'd rather have any replacement parts I need on hand.
Thank you!
Thank you!
