Plainsman
- WRT311FZDW00
- Whirlpool
- 1-5 years
Ice maker isn't filling with water. Installed new water valve, but no change. Installed new ice maker, no change. When I check the inlet pipe and the ice maker, it seems as though the water inlet pipe is right against the plastic piece in the ice maker that diverts the water down into the icemaker cube area. This worked well before, I'm not sure what might be the issue. It just ran (you could hear the solenoid go and water flow, but it seems as though the water was sprayed on the back of the freezer. I found the water inlet frozen yesterday. I shut the water off to the ice maker to continue troubleshooting today.
Thanks in advance,
Thanks in advance,
