Sorta2
- WRV976FDEM00
- Whirlpool
- 6-10 years
Hi all I have been having issues with my fridge for a bit. First the ice maker went out then within a week or 2 maybe the fridge wasn't staying cold or frozen. I did some youtubing and found my evap coils were a block of ice. After thawing I did a resistance test on the thermistors attached to the evap fan, both were bad. The black one I couldn't get a steady reading on and the white one showed an open circuit. I ordered the fan and thermistor assembly and a new ice maker, and installed both.
Everything looks like it is working but it is not getting cold. I found out about the control board troubleshooting guide under the door hinge cap and went through that. On my paper there is no Service Test 6. There is a test 06 on the control display and when it does that test it flashes 03. Since there is nothing on my sheet I have no idea what this means.
I found another manual online that lists my model number and it has service test 6 as "Defrost Heater/Bi-metal" and it only has: 01 for bi-metal closed and 02 for bi-metal open. I went through all the other seemingly relevant service tests and everything seems to check out fine. There were no malfunction codes on service test 66. What should my next step be? Thanks
