- WRV976FDEM01
- Whirlpool
- 1-5 years
Hi
My Whirlpool WRV976FDEM01 started to have an issue today. It is just under 4 years old. There is power to the front panel so I can control the temp, ice maker etc. When I open the fridge there are no lights on inside and the deli draw which lights up and allows you to cycle through different settings has no power as well. The water does not work nor does the ice dispenser. They both worked 4 hours ago. Both the fridge and Freezer are both still cold.
I reset my breaker on my panel and that did not change anything. I unplugged it and plugged it in again still no change. The plug is working as I tested it with a light so it is not an issue at the plug.
Not sure what the issue could be
Any advise would be greatly appriciated
