FIXED Whirlpool Refrigerator WRX735SDBM00 Ice maker arm won't lower on new ice maker
Trichter269
Michigan
WRX735SDBM00
My ice maker recently quit working so I bought a replacement. I ordered an OEM ice maker and after installing the arm I noticed it's stuck. I could find very little information about how the arm should work on a new warm ice maker so I plugged everything in finished the install. It's been about 4 hours and it doesn't appear to be working still. I'm not sure if I didn't something wrong or if perhaps I got a dud ice maker
Here's the OEM ice maker for your model, in case others need it too:
Ice Maker W10882923
Its currently in-stock here: https://www.repairclinic.com/PartDetail/Ice-Maker-Assembly/W10882923/4455397
It comes with new wiring that you MUST replace as well.
I've replaced many of these ice makers and the arm is semi-up when you install it, then after you install it and power is going to it the arm will start to move down and you will hear it FILL with water before it goes all the way down.
Watch this video:
Trichter269
Michigan
I didn't replace the wiring harness but the plug on the front of the ice maker is identical. Is there any other reason the wiring harness must be replaced? The ice maker was on all night and didn't go through any of it's cycles. I apologize for not know all the technical terms but I greatly appreciate your help.
Trichter269
Michigan
Sorry I'm new here. I don't think I replied to your post properly but commented on the thread. Also wanted to add that I did a resistance check on the new ice maker motor and could not get a reading from it.
Whenever a part comes with a new wiring harness in it and includes the instruction sheet, you must follow that instruction sheet to install it properly or it will not work.
So, I'd at least remove the ice maker and follow the instruction sheet and put the new wiring harness in it and see if it works.
Like I mentioned I've replaced about 5 of these ice maker kits in the last couple years and of them worked perfect after I was done.
Ok, sounds good.
Trichter269
Michigan
I swapped the wire harness and that did the trick. While I was removing the old one I noticed the problem. A few of the ground wires on the ice maker had been pulled out of the plug. Thanks again for your help.
Excellent, good job.(y)
