- WRX735SDBM00
- Whirlpool
- 6-10 years
I originally posted last year about my ice maker not working. I swapped the ice maker, ice maker harness and the water supply valve, to no avail.
After some more input from this site I replaced the fan motor on the ice maker housing even though in test mode it said the fan was fine. This solved the problem and my ice maker was working again.
However, recently I am back to having the same issues, then ice maker will only periodically make ice. Sometimes, it won’t produce ice for days, at other times it will make 2-3 batches if ice per day.
Could the fan be bad again? Does the damper control on the ice maker housing have anything to do with temp inside the ice box and could it be bad?
Any other thoughts?
Any other thoughts?
