Whirlpool Refrigerator WRX735SDBM00 no power to icemaker, but power to auger motor and harness good
drewken
WRX735SDBM00
Whirlpool Refrigerator WRX735SDBM00 no power to icemaker, but power to auger motor and harness good.
I replaced the ice maker but still not getting power or test harvest. Could it be a short inside of the Auger motor harness somehow. Is there a fuse inside of there?
Power is going inside to Auger motor but not coming out to the ice maker.
When you ordered and replaced the ice maker is should of come with a new wire harness, did it?
This ice maker comes in a kit with wiring that MUST be installed as well. I've replaced many of these Ice makers and the wiring that comes with it and they all worked perfect.
Here's the OEM ice maker kit for your model:
Ice Maker W10882923
It comes with new wiring that you MUST replace as well.
Note: There is a thermal fuse that clips to the ice maker tray mold, if that fuse is OPEN, you will NOT get power to the ice maker, you can ohm test that fuse for continuity.
drewken
I purchased this one off amazon.
So the wiring must not be compatible..is what your saying. Ok I will go for the one you suggested.
Send that one back to amazon for full refund, and order my link above and you will be back in business.
That one at amazon is aftermarket and it will not work on your machine.
Watch this video:
Ok sounds good.:)
drewken
Well, installed the new icemaker and harness, still same problem. The auger motor works, the fan works. But I can't get a test harvest by shorting T - H or any voltage readings from the ice maker from V- N. This would probably mean the control board is faulty I assume? One other small thing. On the LED panel the light for "cubed ice" never comes on. Only the light for "crushed ice" will light up. Maybe a symptom of the problem?
Any advice.
That's very odd,
L and N are the test points on the ice maker module you check for 120 volts, make sure the door switches are pushed in first.
On your main control board use your volt meter and check for 120 volts at connector P3 Pin 3 violet wire and connector P1 Pin 2 white wire and see if you have 120 volts.
Main Control Board W11035835
It looks like its out-of-stock at RepairClinic, but in-stock here: W11035835.
