Whirlpool Refrigerator WRX735SDHZ00 deli drawer lights
Petabyte
Louisiana
WRX735SDHZ00
Hi folks, new here. I tried to search for similar posts and found one about lights, but I still have a question. Where can I find instructions on how to disassemble the housing that holds the deli drawer lights? It doesn't seem as if they are hard to replace, just can't figure out how to access them. Also, they appear to be round from what I can tell in the pictures that I took. Need to cross reference the parts to buy them.
Adam
Hi Adam,
Here's the parts diagram of the DELI area and I don't see anything that looks like lights in the parts diagram.
Here's the parts diagram for your model, can you point out which it is in your photo?
I looked again. It is in the frame above the deli tray. I am including pictures. I also figured out that they are oval, not the round areas that I sent in previous pictures. I've attached a pic of the area that I am talking about. They are on the underside of that. Left side is barely lit, right side is out. Need to figure out how to remove those lights and replace. Hope this helps, and thanks, Jake.
Thanks, those photos help!
Those run in series, so when you replace the dead LED light the other LED light will work normal again.
Here's the LED light part you need for your deli:
W10695459 Module
Watch this video below, he shows you how to replace it:
Yes, that should fix it, let us know how it goes.
