- WRX986SIHZ00
- Whirlpool
- 1-5 years
Hello, new to the forum, but tried to search for answers and realized everyone's problems may be unique/varying circumstances.
Saturday we noticed that our freezer in our <3 year-old WRX986SHIZ (Purchased 2019 December) was warmer than it should be (30F), we moved everything to the stand-alone freezer and began troubleshooting. Using the tech sheet in the hinge, we ran the same tests asked of many forum posts.
Note: Fridge is cooling fine.
Have not tried defrosting, nor have I pulled the back evap panel to inspect yet.
Run the following tests and post back the results:
Service Test - 1: FC Thermistor
The board will check the resistance value of the thermistor and display flashes results on the Temp display (01 = pass, 02 = open, 03 = short).
01 Returned
Service Test - 2: RC Thermistor
The board will check the resistance value of the thermistor and display the results on the Temp display (01 = pass, 02 = open, 03 = short).
01 Returned
Service Test - 3: Evaporator Fan and Air Baffle Motors
Control the RC and FC evaporator fan motors by depressing SW3
01= both fan motors off. 02 = FC fan on.
Depress SW3 once to advance. Service Test 3 will flash quickly and advance to tests 13/23 very quickly. The result is RC fan on, pantry air damper on. Pantry air damper will open and close automatically (13 = damper open, 23 = damper closed). Verify airflow inside pantry on left hand side when damper is open (13 displayed). Airflow in pantry will cease when “23” is
displayed.
I believe I felt & heard airflow in pantry.
Depress SW3 to advance to the last step (04 = both RC and FC fans on).
Service Test - 4: Compressor/Condenser Fan Motor/ Evaporator Fan
There will be a delay of 3 seconds before start of Sub Step 01. NOTE: Each test is timed and will automatically proceed to the next step. User will not be allowed to exit test. If exit is attempted, an invalid chime will sound. Control the sealed system loads by selecting SW3
01 = initialize dual evaporator valve in home position (4 min.)
02 = close both RC and FC evaporator valves (1 min.)
03 = turn compressor on (1 min.)
04 = keep compressor on. Drive the valve to RC position and turn RC fan on
05 = keep compressor on. Drive the valve to FC position and turn FC fan on
Verify airflow from the evaporator fan.
NOTE: Advance quickly through Service Test 4 to keep from locking in. Once locked in, you cannot exit, and must wait approximately 10 minutes.
Unsure of results here, Missed the timeout to step through quickly and was confused about the 10 minute (11 in my case) lock in
Service Test - 5: Compressor Status/Speed
Initial Display 02 = Minimum speed
Depress SW3. Display = 03. Compressor ramps up to maximum speed.
When maximum speed is reached, 01 is displayed.
Depress SW3. Display = 04. Speed ramps down from maximum to minimum speed. Display = 02.
Tested and returned 01 and 02 as expected.
Added complete model number
01 Returned
01 Returned
displayed.
