Whirlpool Refrigerator WSF26C2EXF01 Replacement Wire Harness For Broken Ice Maker
postlapsaria
USA
WSF26C2EXF01
I am running into the typical frayed wire issue that seems to be so common on this WSF26C2EXF01 model. I see that the majority of people are either soldering or fixing using butt splicers. On my freezer, the wires are frayed so close up to the actual freezer door that it is almost impossible to do any work on them. I was hoping that someone could help me find the replacement wire harness? The ones that I found on whirlpoolparts.com don't seem to look like the exact wire harness that I need. Hopefully I can actually replace the wire harness itself. I checked the service manual, and other documents posted here but wasn't able to locate the exact part number.
Unfortunately you can only get the new wire harness only when you order the complete freezer door assembly: Dor-Fip St LW10371916
Other than that, I'd get extra wire and solder the extra wire on where you see the wire breakage close to the door.
