Whirlpool Stacked Washer/Dryer The washer will pump the water out but it wont spin
RicksHS
seattle
LTE5243DQ2
Whirlpool Thin Twin model LTE5243DQ2 The washer will pump the water out but it wont spin unless i open the machine and rearrange the load. Then it spins but sounds like it's working very hard to do so. Thanks for any input you may have.
RicksHS
seattle
Thanks, I'll try that. And if it works normal, what are you thinking? As well as if it does the same?
Rick
Could be a clutch or spin tube issue. Remove the agitator and see if the drive block is on the spin tube
