FIXED Whirlpool top load washer WTW4800BQ0 no hot water
TonyD8585
Michigan
WTW4800BQ0
Hello,
I have a question similar to this thread on a Whirlpool Model WTW4800BQ0, I am having troubles with the Hot water setting. The Hot water works on Hot but does not work on warm or cool settings (all settings Hot, Warm, Cool, Cold, Tap Cold). I have tested the current at the solenoid on 3 settings, Hot 116volts, Warm 0 volts, cool 0 volts. I have also tested for resistance directly the Thermistor and at the pins (9,10 for this washer) and get two readings depending on switching the voltmeter leads, 424 & 1374 (ambient Temp 85degF).
I was wondering if you could help me diagnose further if its the Thermistor or the Control Board?
Thanks in advanced! Tony
Ok, another member was having a similar issue on a similar Whirlpool model, it the rotary water temperature switch that fixed his:
Do exactly what I mentioned him to do--->I'm attaching your tech. data sheet below, Do TEST #2 Valves
Do this First--->1. Check the relays and electrical connections to the valves by performing the Cold and Hot Valve tests under Manual Test Mode on page 9. Each test activates and deactivates the selected valve.
Like he mentioned if the COLD works in Manual Test Mode, then the rotary water temperature switch is the culprit.
Unfortunately, the tech. data sheet doesn't tell us how to test the rotary water temperature switch. Also check for any pinched or broken wires at the water temperature switch.
Here's the rotary water temperature switch for your model:
  • Tech Sheet - W10468340 - Rev C.pdf
TonyD8585
Michigan
Thanks Jake, I have ran through testing the valves, resistance at the solenoids, voltage, and resistance at the thermistor.
I went ahead and purchased a new switch and will let you know what I find! Appreciate the input!
Did HOT water come out when you did the Manual Test Mode on page 9?
TonyD8585
Michigan
Yes the hot water did come out on the manual test for both Hot & Cold. Hot water valve does not open when switch it turned to Warm, Cool, Cold.
Tony
Ok Tony good.
So that means the Rotary switch should fix it.
Excellent Tony, glad to hear the new rotary water temperature switch fixed it.(y)
