neverwpool
- WHD560CHW2
- Whirlpool
- Less than 1 year
Hello,
Very frustrated with this machine and wouldn't recommend a ventless dryer despite some of the nice features (gentler drying, softer clothes, no need for exterior venting). It just seems too poorly built.
Recently I received some guidance on this forum to replace the drain pump assembly of my nearly brand new (about 4 months old when it stopped working) Whirlpool ventless dryer, which solved that problem. It ran great for..a month or so? I'm pretty sure my new issue is unrelated, as the drain pump is working fine. I can hear water going down the drain periodically.
Now, the past 3 times I've run it I'm experiencing a new issue. The dryer will run for approximately an hour, then the drum stops spinning. The control panel still shows an accurate time, and continues counting down towards zero, but the dryer is otherwise not working. It sounds like the compressor, or maybe motor is running at low power (something is running with a low hum, and it sounds kind of like when my outdoor heat pump is on). After a couple minutes of humming, a fan kicks on. If I try to turn it off and back on, the hum goes away and the only thing on is the control panel timer - the dryer makes no attempt to start spinning again. I get no error codes (I've done the diagnostic steps in the tech manual) - only thing that may be different than when it is running normally is that the 2 LED on the far left of the machine will flash 3-4 times before the machine turns off when I hit the power button. If I turn it off and wait an hour or two it'll usually fire back up and finish the load.
Right now it is doing the humming thing and I'm letting it go for 10-15 minutes to see if it starts back up or not.
I have a few guesses, curious what you think would be the best place for me to start on this hunk o' junk:
1) overheating? I have the dryer in a small 3rd bathroom with poor airflow. I run it at the lowest of the 4 temperature settings, but the room still warms up a fair bit.
2) jostled something loose? I just had to unplug the dryer and move it out of the way to repair the water pump on my really old washing machine. This issue started the first load after I got the machines back in their normal spots. I'm guessing this is coincidence.
3) control panel failure? Long story..but I have a spare. Should I swap and see if it works better?
4) moisture sensor? This seems to be mentioned in several parts of the tech manual when talking about dryer stopping randomly
Please let me know your best guesses so I can try to fix this cursed dryer yet again.
