Here's your tech. data sheet:
https://drive.google.com/file/d/1pPEXw7rQUARNdrtWcrvEKY3llYEjjNbq/view?usp=share_link
F8E1--->NO WATER DETECTED ENTERING WASHER OR WATER LEVEL SENSOR TRIP NOT DETECTED--->The washer does not detect water input after 12 minutes of filling.
Possible Causes
• Is water supply connected and turned on?
• Check for blocked or kinked inlet hoses.
• Low water pressure or blocked hose screens.
• Check for proper drain hose installation. Is water siphoning out of the drain hose? Drain hose must not be more than 4.5" (114 mm) into drain pipe. Make sure drain hose is not sealed into drain pipe, and that there is an air gap for ventilation.
• Check connections from tub to air trap, air trap to pressure hose, and pressure hose to water level sensor.
Is pressure hose pinched, kinked, plugged, or leaking air?
• See TEST #6 (Water Inlet Valves) on page 16.
• See TEST #7 (Water Level Sensor) on page 17.
If you have plenty of water pressure to the machine, and the water inlet valve screens are not clogged, then the problem is the water inlet valve itself.
W10599356 Valve
Let us know how it goes after you replace it.
Another member had this same issue and his model uses the exact same water inlet valve yours does and that fixed it:
I am getting the f8e1 error frequently but not with every load. The pressure incoming on both hot and cold is good, the hoses are not kinked, the filters are not clogged, & the drain is not clogged. The washer takes forever to fill. I read that there was a similar problem with model #...
www.applianceblog.com
