FIXED Whirlpool Washer WFW9150WW00 won't drain and won't complete cycle
DIYJC
NY
WFW9150WW00
I have a Whirlpool washer, model wfw9150ww00. At first the problem was intermittent - it would stop midcycle, not drain, with 3 rapid chirps. The door stayed locked. I was able to reset it and get it working again by flipping the breaker. That no longer works now.
I have run the diagnostic and gotten a f1e1 error code. I cleaned out the filter (there was some debris) and fixed a broken grounding wire coming from the rear hub. I double checked for secure connections between the MCU and CCU and drain pump and CCU and it all looked good. I cleared the error code and reran the automatic diagnostic test which completed it's cycle with no additional errors. I then ran a regular wash cycle once again but it stopped mid-cycle, gave me the 3 rapid chirps, and showed the f1e1 error code again - argh. The cycle seems to fail/stop right as the drum is set to drain.
I'm unable to figure out if I have a drain pump problem or a CCU problem. I also read a post that said a pinhole in the water pressure hose can cause this?? My hose is well protected so don't think this is an issue but hard to know for sure.
Anyone got any words of advice? thx
Measure the resistance across the drain pump terminals. If it's not 15 ohms replace the pump
DIYJC
NY
using two different meters, I'm measuring between 11.8 and 12 ohms at the drain pump terminals. not quite 15 ohms. would this still indicate the drain pump is the problem?
DIYJC
NY
I have a new CCU on order which should arrive in the next day or so. There are a good number of posts indicating the F1E1 code is a communications related error that can be solved by other (read "cheaper") fixes, like wire harnesses not seating right, harness pins not contacting correctly, pressure sensor errors, drain pump errors, etc. I've been troubleshooting for a while with no luck on all that so i'll see if the ~$300 CCU replacement does the trick and move on with my life if it does.
F1E1-Pump Driver/Main Relays/EEPROM Error
The pump driver fails to activate/ One of the main relays is not working properly/ A communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred.
DIYJC
NY
Update: After significant resistance testing many components (all of which checked out), I went ahead and ordered a replacement CCU, got it installed and everything seems to be working now. ~$300 part but now there's clean laundry again. good luck out there.
