Whirlpool washer WFW94HEXW2 F6E1
SeanSean
Union City, ca
WFW94HEXW2
I get the error code F6E1. When I ran the quick diagnostics test it locks the door and just sits at C00. C00 is supposed to lock and unlock and then lock the door but I only hear it lock the door. I ran Test#4 Door Lock System from the manual and the door lock coils are stated to be 50-74Ohms but when I measured them they were 165 Ohms.
Does this mean it's the lock assembly that needs replacement?
This puzzles me as it does lock. The C00 test says it should lock, unlock and then lock but I never hear it do that and it simply locks and stays at C00. I have yet to test the MCU unit.
Thanks.
I've seen this F6E1 error code many times on my service calls, 9 times out of 10 you will see a burnt spot on the MCU, that is the bad part. So I'd first disconnect power to the washer and remove the MCU from its plastic casing and look for burnt spots on both sides of it.
Here's the MCU for your model:
WPW10374126 Motor Control Board
On your model you access the MCU from the back of the washer, you have to pull the washer out from the wall, then unplug it, then remove the back access panel and you will see it on the bottom of the washer base.
Here's the video:
SeanSean
Union City, ca
I pulled the MCU, from the machine and noticed one of the chips is blown. The top blew off (part number LNK304GN) as you can from the two pictures. The second picture I placed the top part back on the chip showing a cracked line. Attached are the images of the board. It seems this must be the issue. I'm wondering if I can simply replace the chip?
As techs we have to replace the whole MCU board.
I don't know if just replacing the chips will solve the problem. I know replacing the entire MCU board will for sure.:)
SeanSean
Union City, ca
Thanks Jake. I will try to replace the chip and see how it turns out. If still issues, I will just order a new MCU board.
There is a resistor next to the burned chip. Do you know what that value should be? The numbers seem to be burned off and I can't make it out. I attached the image of the resistor in question.
Thanks.
