Whirlpool Washer WFW97HEDC0 - Persistent E01/F03 error and also Loud Pump
Jamers99
Lutz, FL
WFW97HEDC0
I have the Whirlpool Duet WFW97HEDC0 purchased in 2015. Been battling against the dreaded E01/F03 error code for the last year now. It comes and goes at random. Cleaned everything out like it was brand new. Also, I have noiced the pump seems to be louder than when it was new..at least to my ear. Not sure of that is a sign of a pump going bad over time?
Today I gave up and ordered a new pressure switch as well as a new pump.
Also, is there a replacement part for the larger circular rubber seal on the front of the unit? Not sure exactly what it is called. Mine has gottten rather stained from mold/mildew over the years.
I located a service bulletin for this error code, I'm attaching it below.
Its has to do with the air trap assembly aka Air Dome assembly.
The manufacturer has replaced part number W10626116 with part number W10903220
Here it is for your model you can order(Video is included in this part link):
Air Dome W10903220
Door Boot Seal(Bellow) is what its called:
Bellow WPW10237493
  • Service Pointer - W10803528 (Air Trap Assembly Blockage).pdf
Jamers99
Lutz, FL
Hi Jake, thanks but I actually already changed the Air Dome Assembly with that newer one about 9 months ago. I read one of your earlier responses on this forum. I'll report back after I swap the pump and pressure sensor.
Yes, its most likely the drain pump then.
Another member had a similar issue:
Jamers99
Lutz, FL
Hi Jake, I can tell you I dissasembled the pump and verified nothing is blocking the impeller.
Then its the bearing in the drain pump that's making that noise, I've run into this problem many times on my service calls.
