Whirlpool Washer WTW4816FW1 stops before rinse cycle/won't turn on.
24janet
Houston, TX
WTW4816FW1
My washer would stop after the wash cycle. I would have to turn on the rinse and spin cycle manually instead of it finishing a full cycle on its own. I found it could be the lock sensor and found how to put it in diagnostic mode but now the washer won't turn on any lights. I do hear a humming sound coming from the back and I'm hoping it hasn't fully given up on me!
Pull the machine out from the wall, then unplug the machine and remove the rear top console access panel to access the main control. Restore power and check the service LED on the control. Is it off or on?
Ok, good.
I'm attaching the tech data sheet below for your model.
Page 10--->WON’T POWER UP
• No operation
• No Status LEDs
Main control not properly installed in console--->See TEST #4: Console and Indicators, page 16.
Main control problem--->See TEST #1: Main Control, page 12.
Here's the Main Control board for your model:
But its out-of-stock most everywhere I've checked.
  • Tech Sheet - W10740624 - Rev B.pdf
