Whirlpool Washer WTW4900BW0 Not starting cycle
cjk
Mobile Alabama
WTW4900BW0
Press start and the sensing and lock lights come on, lid lock locks.
It'll spin for a second and stop. It'll sit like that a few minutes, time out, done light comes on, sensing and lock lights go off, lock unlocks.
I ran it through the Automatic and Manual tests. Ran through the Tachometer Verification Mode and Calibration Mode. Everything works.
Get F7E6 fault code, but all agitation and spin tests worked in Manual and Automatic tests and Calibration Mode.
Ok, Do a Drain/Spin cycle ONLY and report back.
If still the same, then that usually indicates a control board problem.
Here's the control board for your model: W10582042
Ok, so its not filling with water after you start a new cycle?
I'm attaching your tech. data sheet, go into MANUAL DIAGNOSTICS and activate the HOT and COLD water fill tests and see if each puts water in the tub.
  • Tech+Sheet+-+W10468340+-+Rev+C.pdf
cjk
Mobile Alabama
They work, I've done all tests in Manual Test, Auto Test, Calibration, no discrepancies. Everything works.
Then it must be the control board.
Happy New Year!
