RenegadeCJ
- WTW5000DW1
- Whirlpool
- 1-5 years
The current problem is after washing clothes, clothes are still dripping wet, had to run two drain and spin cycles to get dry enough to run in dry (takes several dry cycles to dry then as well).
so then I ran the following diagnostic tests
not showing any codes
in the past, I have had a problem with it not agitating and replaced the hub under the wash plate, (also failed to calibrate afterward)
Model # Information![20210911_023448[1].jpg 20210911_023448[1].jpg](https://www.applianceblog.com/mainforums/data/attachments/54/54543-40ecbd975d7b3a8f4fb06636e266472b.jpg)
First test low agitation
second test high agitation
the third test was low-speed spin
the video was too big first try nothing happened
The second time went to low-speed spin
the fourth test was high-speed spin
the last test was the tachometer test
Model # Information
