Whirlpool Washer WTW5600XW0 not spinning or agitating
edjwestphal
Portsmouth NH
WTW5600XW0
Hello,
We got a Whirlpool Cabrio from a friend, not exactly sure how old it is but the serial starts with C1, so I think its 10 years old. It's always been excessively loud but had run for the few months we've had it.
Recently we've found that several washes have ended with the clothes still soaked in water. Running a Drain & Spin afterwards didn't help either.
I'm working with this manual: https://www.applianceblog.com/mainforums/attachments/tech-sheet-w10240504-3-pdf.23947/
When I first checked the codes I got F7E1. I ran it through Automatic Test Mode and it agitated but didn't spin. I tried unplugging my washer and turning off power to the laundry room and redoing the Automatic Test, with the same result.
However I read a post on here recommending I clear the codes and then run heavy agitation. I cleared the codes, and tried to run heavy agitation in Manual Test Mode, which didn't work. I then tried both Low Spin and High Spin - neither worked and no sounds were made at all.
I tried running Automatic Test Mode again - and now the washer doesn't agitate or spin, it just skips the cycle for agitating and ends the Test instead of spinning. When trying to recheck the codes I get F0E0 in all of the last 4 codes.
I did not take the washer apart. I cannot move the basket when the washer is not plugged in. I ran the Manual Drain Test but I can hear water sloshing around inside the washer, but I cannot find a leak.
Any advice would be helpful, I'd like to save money by fixing it but I don't have any experience fixing washers other than the past day of faffing around.
Thanks, Ed
I've seen this before. There may be a loose electrical connection. Check electrical connections at the motor, actuator, capacitor and pump, Disconnect the wire connectors and then reconnect them making sure they are on all the way.
edjwestphal
Portsmouth NH
Thanks for the reply Rick, I took your advice this morning. I flipped it over and removed the plastic covering. I un-attached and re-attached connectors I could find. I think I got all of them - the actuator (red), the pump (the grey box I had to open), the motor (the beige/manila), and the capacitor (the black cylinder).
There was an ounce or two of water in the metal shell, which I cleaned up. I did run my hands on the components to see if any of them were wet but everything seemed dry.
After re-plugging in everything, I tried the Automatic Test Mode again. I heard it agitating. When it came to the Spin Test, it made the usual groan sound but didn't start spinning. Then it skipped from the Spin Test [ display 12] over the Sensing a Stopped Basket [ display 13] to Lid Locked Until Cycle Completes [display 14]. I had to manual end the test after 5-10 minutes of waiting.
Rechecked the error codes and got the F7E1 error.
I did not see any noticeable problems with the wiring but I had no idea what I'm looking for. I've attached some photos.
Look what I found. I think it might be helpful:
  • WTW5500XW0-servicepointer-w10606242-basketspeedsensorfault.pdf
