FIXED Whirlpool washer WTW7120HW not draining and throwing code F9E1
Jharv
Vandergrift Pa
WTW7120HW
The washer started not draining and throwing code F9E1 which was not draining. I checked all the hoses and replaced the pump. It would drain when you tilt it up. Now it’s the code F3E2. I have know idea what’s wrong. Also when I pick up on the tube it makes a clicking noise and then will drain.
Here's the tech. data sheet for your model: https://drive.google.com/file/d/1lmS6Y7TCYTY1-7YqEqLReEH8w6HeXo3K/view?usp=sharing
F3E2--->Pressure System Fault
Fault is displayed when the main control detects an out of range or absent pressure signal.
--->Check pressure hose connection from tub to main control. Is hose pinched, kinked, plugged, or leaking air?
--->See TEST #6: Water Level.
Did you disconnect the pressure switch hose when the drain pump? If so, make sure its back in place again. If so, make sure no water is in the tub, then blow through that pressure switch hose really hard and see if that resolves it.
Jharv
Vandergrift Pa
Blew air threw the hose and ran it. Half way through the cycle it threw code F9E1again. I am lost. Don’t have any idea.
F9E1--->Drain Pump System Problem - Long Drain
Fault is displayed when the water level does not change after the drain pump is on.
--->Is the drain hose or the drain pump clogged?
--->Is the drain hose height greater than 8' (2.4 m)?
--->Is the pressure hose connection from the tub to the main control pinched, kinked, plugged, or leaking air?
--->Too much detergent.
--->Is the pump running? If not, see TEST #7: Drain Pump.
Run a cycle WITHOUT CLOTHES and WITHOUT DETERGENT on COLD ONLY and see if you get that code again.
If so--->Is the pump running? If not, see TEST #7: Drain Pump.
Jharv
Vandergrift Pa
All hose are clear and right size. I did try running without clothes and now has water stuck in it. I did that yesterday so I did not run without detergent. Can’t get water out of it.
Then its either something stuck in the drain pump, or the drain pump hose is clogged or the drain pump is faulty, or your not getting power to the drain pump when it should be running.
Use a multimeter to check for 120 volts at the electrical connector that goes to the drain pump, when it should be running.
I know that, but you missed what I said here: Use a multimeter to check for 120 volts at the electrical connector that goes to the drain pump, when it should be running.
If you DON'T get 120 volts to the drain pump it will NEVER run, so I'd check for a broken wire first from the control board to the drain pump, if no broken wire then your control board is the culprit.
Main Control Board Replacement W11419051 Video
rhefley
SC
@Jharv What you are describing is exactly what I have experienced and was able to fix thanks to another post on this forum, so I made an account on here just to thank the user (@Mlw35405) that posted the solution that worked for me, and maybe the same will work for others facing this issue.
If you find that the drain pump will not start when there is a heavy load or if it keeps cutting off and on when the load is unbalanced, it could be a faulty wire going down to the pump that comes separated when the drum is weighed down with a load. You have to strip away the tape surrounding the wires going down the back of the drum to find the split and repair it. It does seem very odd for a wire to come separated in the middle like this, you would think the harness going into the board or into the pump would be a more likely point of failure. But this was the case for me and for @Mlw35405 - hope this helps!
Thanks @rhefley for posting that.(y)
I'm glad you found it was just the broken wire on yours too.
