FIXED Whirlpool washer WTW8800YC1 SD Error Code
DLMerritt08
Kentucky
WTW8800YC1
Hello,
My whirlpool washer is giving an SD error code. I have checked for blockage and ran a hot water cycle. At 16 minutes left in the cycle the tub went empty but the drain pump kept running for a long time even after the tub was empty. Finally when the SD error came up the washer started filling with water again and it filled up above half. I then pushed the power button to stop it from filling and it drained out. I felt like it drained out pretty quickly. Everything looks good inside the pump as far as blades.
A lot of reviews state to change basket hub kit. The agitator looked to be working fine with no load in there.
I’m not sure if that is my issue. It’s almost like something is not telling the pump to shut off which is telling the control board it’s still full.
Thanks for your time,
Yes, usually SD error is the basket hub.
Read post #7 here:
That Kenmore is made by Whirlpool and uses the same exact basket hub yours does.
Here's the basket hub for your model:
W10820039 Basket Hub
Video Included in Part link.
Let us know how it goes after you replace it.
Ok, sounds good.
DLMerritt08
Kentucky
Hey Jake, great news! Replacing the basket hub did indeed fix the issue. It ran a cycle last night with no issue.
Thanks again for your time and information.
Regards,
Excellent DL, glad to hear the new basket hub fixed it.(y)
