FIXED Whirlpool WFC7500VW0 not spinning
Gandy
Acme, PA
WFC7500VW0
Our Whirlpool WFC7500VW0 (compact front loader)is acting up. I replaced the door latch and switch as it wasn't always starting the cycle. That appears fixed. Along with that issue, the washer sometimes doesn't spin/high speed spin to complete the cycle. Two loads ran fine yesterday, the third went to about 12 on the countdown and then ended. Now it won't complete a cycle. Seems likely its the MCU or the CCU but which?
When it drains pull the drain hose up from the drain pipe and watch how fast the water pumps out, it should pump out extremely fast.
If that's fine, then unplug the washer from the wall outlet, then remove the MCU and check for any burnt spots on the circuit board. If you see burnt spots on it, then its causing this problem.
Here's the MCU for your model:
Motor Control Board WPW10192965
Did you see a burnt spot on it?
Ok, yes usually the MCU is the culprit when it does that. The good thing is that if the MCU does not fix it, you can return it for a full refund, less shipping.
I just located the repair manual for your model: https://drive.google.com/open?id=0BzvgAyLTSh14dHJrSnQ0QVMzTDA
There is a diagnostics test on page 6-8 you can try to do as well.
Hi Ming Ming,
As far as testing the MCU other than looking for burnt spots on it, I don't see any way to test it per the service manual I posted in post #6.
Hopefully another tech. that's run into this problem and fixed it can shed some light on this for us.
Gandy
Acme, PA
Swapped out the MCU today. Made no difference. Ran a cycle to about 10 then ended. Guess I'll try the CCU next. Won't be long before a new washer would have made better sense!
Gandy
Acme, PA
I have the CCU. Swapped it out and went to test. The green wash light is lit up even when the dial is "Off".
Looked more closely.The original is marked 11011AE on a blue sticker, the replacement is marked 11011AH. Did I get an incorrect part? Any other ideas?
Gandy
Acme, PA
Solved the problem with the light. I mispositioned the dial into the CCU. Corrected that.
We tried a rinse/spin cycle. Went through to about 10 and shut off. With a new MCU and CCU what's left to try?
I do not know, never seen that happen before. You'll need to have Whirlpool come out to see what's going on.
There's nothing else I'm aware of to try.
johnghadimi
Houston
Did you ever have a resolution on this? My machine has recently started doing the same thing. I hate to spend 300-400 on it when I can probably buy a new one for the same cost!! What a pain. I should have extended that extended warranty. :)
Gandy
Acme, PA
Swapped the MCU and the CCU. Also changed out the drive belt(no clue what that would have to do with it but the wife found a post claiming it helped. Easier to change than argue). Washer has been working well for the past 2 months.
I'm ~$450 into parts and the fun of working on it, but it currently seems fine.
johnghadimi
Houston
wow that's awesome and sounds like loads of work. The thought of dismantling my setup and doing all that gives me major stress. :) I'll most likely reach out to Whirlpool and get their advice on this and figure out if it's worth the cost to fix or just buy a new unit.
Gandy
Acme, PA
skipping the cost aspect, it was really maybe 2 hours including all the first time slowness, repair manual is linked above and pretty good.
The Belt? That's very interesting, usually when the belt goes bad it will squeal or just break. Glad to hear the new belt fixed it. (y)
Here's the belt for this model:
WPW10192984 Belt
You know at RepairClinic you have 365 days to return any part for any reason, even if you installed it, for a full refund, less shipping?
Gandy
Acme, PA
I'm not so sure the belt actually "fixed" it.:unsure: It was worn and stretched enough changing it wasn't a bad thing.
Ok Gandy, got it!
Thanks for letting us know about the belt though.
Gandy
Acme, PA
Don't tell my wife,but I really think that running a full cycle was what "solved" the problem. It had a definite issue, changed the MCU. She tried either rinse and spin or drain and spin with no success. Then I changed the CCU. She tried the same cycle with same results. At her suggestion I changed the belt. This time I chose to run a full cycle. Lo and behold, it ran fine. No clue if just the MCU would have fixed it. Doubt the belt was the magic answer. At least it's run fine for the past 2 months.
For anyone with similar issues, I'd suggest running a full cycle after each parts change.
