- WGG745S0FH02
- Whirlpool
- 1-5 years
I have a Whirlpool Double Gas Oven, Model WGG745S0FH02. Both bake functions and broil function won't light up. The igniters will turn on and glow, no gas flow. Top burners work just fine. I tested all of the igniters ohms. All three were within typical igniter range - 135ish ohms. Checked the regulator switch, tried both up and down just to make sure. Replaced the control circuit board and everything works the same. (There was one random time where I switched to a rapid preheat for the bottom oven. It fired up and then turned off at 150 degrees. Hasn't ever done it again.)
I was debating whether to try a new gas regulator, but after the bottom oven came on once I figure it has gas flow... Maybe I'm dead wrong on that. If I leave the bake function on, the oven never throws a code after sitting for awhile without lighting.
