FIXED Whirlpool WMH31017FS0 blowing fuse - initially had door open error
fridge
chicago
WMH31017FS0
Thanks for looking
Microwave is under 2 years old - Here's the sequence of events to the blown fuse:
  • After about 3 months of owning the microwave cooktop light stopped working. I assumed it was the light bulb and never fixed it.
  • About a month ago the microwave light started to flicker and there was clicking when you opened the door. I was going to troubleshoot the door switches when i got time. I believe the top switch is causing the flicker. The microwave continued to "work"
  • About 2 weeks ago i started getting a "Door" open error and depending on how gently you opened the door I could still get the microwave to cook.
  • Randomly the cooktop light starts working again
  • A few days ago i took a pair of needle nose pliers and pushed the top switch in and pulled it back out to see what would happen. It seemed like the switches were in sync, the light came on in the microwave and i thought it was going to let me cook. I closed the door and the fuse blew. Replaced the fuse and to no surprise it blew the fuse immediately when i plugged it back in.
Would a bad door switch cause the fuse to blow? I'm trying to decide how much effort/money i want to put into this microwave. Any suggestions are appreciated. I have no confidence replacing the switch is going to fix my problem any more.
I'll see if Rick can assist you.
You may have more than one bad switch or the latch switch bracket is out of adjustment . There are three microswitches, primary, secondary, and monitor. The monitor switch is also called a "dead man" switch. Whenever the door is open L1 is shorted to N at the monitor switch. When the door is closed the switch is open. Always check resistance and continuity with the power removed from the machine. Open and close the door to check the switches for continuity with the wires removed from the switches.
W10727360 Switch
W10269458 Switch
W10269460 Switch
fridge
chicago
Thanks Rick
Primary switch was shot. Other two were working fine. Replaced the switch and fuse and I'm good.
