Whirlpool WMH3101FS0 microwave doesn't work after Switch Door Replacement
Andrew82
Toronto
WMH3101FS0
I need a little help with a Whirlpool microwave. Initially, when we opened the door, the light was blinking but the microwave was still working. I did some research and I found the issue could have been one of the door switches. So, I ordered a new set but while I was waiting for the shipment coming the microwave stopped working completely.
I finally got the switches and replaced them all, however, and here is the problem, the microwave is still not working (it`s dead like if there is no power). Is anyone here who might know what happened? Could it be the fuse? or the wrong set of switches perhaps? (all the cables are correctly where they are supposed to be).
Thanks in advance or your help!
Andrew
Yes:
I have a similar problem - had door open/close error off and on so replaced the switches but then the fuse blew. All videos i’ve watched on replacing the fuse say to discharge voltage from the capacitor first. I don’t see where to do that on my microwave - see pics below
Rick has been out sick since Jan.12th with a serious illness, we are hoping and praying for a speedy recovery!
I know nothing about microwaves or I would help you.
Hopefully another tech or member can assist you.
