Thomas31093
- WRF767SDHZ00
- Whirlpool
- 6-10 years
I have a Whirlpool Model WRF767SDHZ00 French Door Refrigerator given to me. Since my Kenmore died, a friend had this one and I'm hoping something simple is going on with it. The lower freezer, cold, ice built up on evaporator coil. Fridge section not above 59-60. The evaporator fan was not on. The top LED lights barely flicker, freezer light is out, but side lights work in fridge section.
I read that there is a relay on the control board for defrost timer and a relay for lights. I have also read that the freezer light can go out and cause the top lights in the top of fridge section not to work. The lights I am not worried about at moment. I would like to know is the freezer being cold and fridge not cold, could that be the damper not allowing airflow to the top of fridge?
Also, according to diagram, there is a motor at top of fridge where icemaker is located. That fan at top is not running either but thought that reason could be temperature control in fridge not working causing this possibly. It seems this system a has no leaks as my Kenmore developed a leak at evaporator coil and cause a stink in the house. I am hoping this Whirlpool is a simple fix and be my replacement for my Kenmore.
