FIXED Whirlpool WRS571CIDM01 water leaking from ice dispenser - Fixed
Phroggy
Utah
WRS571CIDM01
Hopefully this can help someone else:
The plastic ice maker was cracked near where it attached to the door.
I have a WRS571CIDM01 side by side refrigerator that started leaking water out of the ice dispenser in the door.
When I opened the door, I found that all of the ice in the ice container was frozen into a solid block.
While working in the kitchen, I heard what sounded like the icemaker harvest motor operate and then heard water dispensing (I assume it was refilling the tray) but I didn't hear any ice cubes drop.
I removed the ice bucket (which was a bit wet and looked up at the ice tray position.
The ice tray appeared to be in the correct position so I pulled the front cover off of the icemaker and found significant ice buildup on the ice tray and around it.
Using towels and careful application of warm water, I was able to melt the excess ice and remove the ice from the ice maker tray.
I dried everything off, reattached the front cover, turned on the icemaker, and let everything run overnight.
In the morning I found water leaking from the ice dispenser again.
I uncovered the icemaker to see what was happening and there was again a buildup of ice. The tray was not dispensing but was then being refilled.
Upon closer inspection, I noticed a crack on the backside of the icemaker assembly.
I applied a slight CW torque to the ice tray and observed the plastic flex right at the crack.
I believe that this was preventing the assembly from applying a enough twist to the ice tray to force the ice out.
Since the motor rotated to the proper position, the system "sees" that a full harvest cycle is complete and then proceeds to the refill step...
I replaced my icemaker with a new unit and everything is working perfectly.
Thanks for posting what was going on with your ice maker.(y)
Here's the ice maker for your model, in case others need it too:
W10873791 Ice Maker
For others following your thread, this video shows you how to replace it:
Phroggy
Utah
Thanks Jake! I am so glad that I stumbled upon this forum. It is incredibly helpful!
I wasn't planning on posting anything but I decided to after I couldn't find another post that mentioned the broken plastic as the root cause of the issue.
Thanks! (y)
