- WRX986SIHZ00
- Whirlpool
- 1-5 years
I've searched through the forum here and found some very similar issues but none quite the same as this mine. The ice maker quit working in the refrigerator a month or so ago. Then a little while later, after unplugging the fridge to move it and plugging it back in, none of the lights inside worked but the outside panel still was lit up and responded to touch. When the lights are out, water will not dispense. Sometimes if you hold the door open the lights will eventually come on, but then when you close it the panel sometimes still shows that the door is open. These issues always co-occur - when it's working, everything is fine, but when one issue occurs, the other happens with it. Eventually it seems to be back to normal and works as expected for days. The red LED in the ice maker tray is sometimes on and sometimes off, but I can't find any information on what the light is indicating.
I've been trying to test the ice maker in service mode and so far it looks like it passed the tests I've read about here. I can't find a full service or operator manual though so I can't say for certain. On this forum, I've read about this model having a non working LED short the LED control board and cause issues with water dispenser, etc., and a bad ice maker assembly stop ice, but I doubt that they both went bad at once so I am wondering if I'm not looking at an issue with the main control board or wiring. I am willing to test whatever if someone can point me in the right direction or to a service manual - I am familiar with wiring schematics and multimeters.
Thank you
Thank you
