- WTW7120HW0
- Whirlpool
- 1-5 years
My whirlpool washer WTW7120HW0 is getting stuck and can't get past the first drain cycle in any wash mode. Started intermittently with any cycle except for delicate and quick which was working for a little bit. Now the washer won't even get through the delicate, quick cycle at all. Gets stuck first time it's supposed to drain at 18 minutes of a 29 minute delicate cycle and eventually errors F9E1. The crazy thing is that if I lift the front of the machine off the ground and rock it back and forth a few times, the machine will drain and then continue the rest of the cycle with draining like nothing is wrong.
The hair-pulling, scream out loud part is that I have done every troubleshooting and replacement possible except for replacing wire harnesses. I have changed the main controller unit and pump, thinking both were failing. First the MCU, then the pump. I tore apart the tub and cleaned to make sure there were no blockages before the pump. When replacing the pump, I check for blockages before and after in the hoses. I check the hose length into the house drain and even adjusted it shorter to the length specified in the manual with no luck. I even tried changing the level of the machine to see if that would make a difference. I'm probably forgetting something, but I went through the F9E1 troubleshooting steps in the manual.
I don't know what else to do. This is an expensive, only two year old machine to be throwing out and replacing already. Any suggestions on what I can do, other than destroy it with fire, would be appreciated. Thank you.
