- WX988SIBM01
- Whirlpool
- 1-5 years
Hello, I have a 2015 Whirlpool refrigerator that has never been cold enough. The Fridge does not go below ~43 degrees and freezer does not get colder than ~15 degrees despite setting them at the lowest settings: 33F and -5F. What's crazy is that it seems like it is warmer in the summer months when the room temperature is 75+ in the house and slightly colder in the winter when the indoor temperature is less than 70 degrees in the house. I don't feel any leaks around the doors and there is no ice build up in the freezer.
I am wondering if anyone could help me troubleshoot this issue or knows of a great technician in the area of Cerritos, CA (90703) that may be able to help out. This is almost a $3000 unit and it's been such a disappointment. We've had technicians out multiple times under warranty (see below) and no one seems to be able to help us.
Thank you for any advice you can provide,
Ken
A "little" history:
1. When first purchased the refrigerator doors were leaking in the center where the plastic flap folds over. The door with the ice maker and the plastic flap were both fixed under warranty after about a month and that the leak was fixed. We still noticed both zones were warmer, but they told us to give it some time to stabilize.
2. We still had the issue months later and so whirlpool sent another technician out to fix it. They replaced a control module. Still not fixed.
3. We then noticed we were not getting ice in the ice maker and another technician came out and replaced a fan on the back of the freezer (I believe it blows air up to the ice maker?) and that fixed that problem.
4. We also had an issue with ice build up in the freezer and it was discovered that there was a leak on the freezer door. That was fixed.
5. We still had the overall cooling issue and the last time we were able to have a repairman come out under warranty, I believe they recharged the system... (not exactly sure that's what they were doing, but i remember them using a tank of fluid and using a torch on some cooper lines).
Ken
A "little" history:
