whrilpool model lcr7244hq1
stall70
imported post
the agitator just spins in one direction when the cycle begins, overflowing the water over the tub all over the floor.some times it works but just for a second or two after it fills, the machine pauses and does not want to continue. if i press the start button after that it just goes another minute and stops again.i replaced the cycle selector switch however it did not cure the problem. any help would be greatly appreciated thank you.:?
imported post
You mean when it fills with water, then trys to agitate the tub starts to spin?
If thats the case, your transmission(gearcase) is bad, and most all have a 5 yr. factory warranty on the part only, you just pay for labor. Check your warranty guide.
stall70
imported post
yes that is what it does when it fills instead of agitating it just spins in one direction
stall70
imported post
its the agitator itself that spins in one direction not the tub
imported post
Try holding the agitator while its trying to turn, and see what it does.
I have to leave for work now, but i will be home this evening PST.
