Why is my Kenmore series 700 skipping the wash cycle? Everything else works fine? No codes pop up or anything. It goes from fill straight to rinse.
Borimami
Daytona Beach
I'm not sure what is going on. It skips from fill to rinse. It does not wash. It absolutely skips the wash cycle. Also it will not agitate.
Added model number
We would need the model number of your washer first.
Click here: Appliance Parts
Ok, sounds good.
We need to model number, not the serial number.:)
The model number should start with 110 or 417 or 796.
Perfect, thanks! I'm attaching your tech. data sheet below.
On Page 4--->WON'T AGITATE
1. Make sure basket is floating.
2. Unplug washer or disconnect power.
3. Check harness connections.
4. Lid switch. See TEST #8, page 6.
5. Motor. See TEST #3.
  • Tech+Sheet+-+W10405149+-+Rev+A.pdf
