Window unit advice...
mjl1297
Brownsville TN
NA
-major brand-
Less than 1 year
I have a 20 x 20 room with 11 foot ceilings. I need a window unit for it as the one currently in use is woefully underpowered for the purpose (8000 btu).
I am looking at the following and was wondering if it would be a good choice-
Any advice would be most appreciated. I would like to go 14000 btu but that would mean a through the wall unit and I have no wish to do that. I also don't want a portable unit.
Many thanks.
12000 BTUs will cool a 450-550 square foot room. You have 400 square feet plus high ceilings so I wouldn't go any less than 12000 BTUs.
tabs0096
Mississippi
What about draining, how do you properly drain these units if there isnt a drain plug? Tilting them back doesnt help dispose of the water buildup in the pan.
They all have a drain under the condensor. Any water that doesn't drain evaporates from the condensor heat.
mjl1297
Brownsville TN
Sorry about the hot link Rick--my mistake.
For those that may be interested though I am looking at the Koldfront WAC12003WCO 12000 BTU.
Thanks for the assistance Rick. That more or less confirms what I was thinking. I plan to get underway with and hopefully finish this project this weekend. I will post updates later on as to how it worked out.
mjl1297
Brownsville TN
I decided to give it a bit of time before updating the thread. I purchased the unit listed above and it has suited my requirements ideally and it is much quieter than the unit it replaced.
