WJSR4160D5WW Only warm water when hot is selected.
RD427
NY
WJSR4160D5WW
Thanks for allowing me to post!!
I have a GE top loading washer with a water temp selector. I have replaced the hose, the inlet valve and solenoids and the water temp selector switch.
for some reason I only get barely warm water when the hot is selected. Is the cold water solenoid supposed to be open when the hot is selected? if I unplug the cold solenoid I get hot water. Is this normal operation?
Any help would be appreciated!!
Here's the parts diagram for your model: GE Washer WJSR4160D5WW Repair Parts
You'll need to locate the tech. data sheet and trace the circuit for the HOT water solenoid and find out what is causing it not to fill with HOT water only.
The tech data sheet should be inside the control console.
RD427
NY
Thank you for the reply.
I found the tech data sheet but, I don't know how to read whether or not the cold water solenoid should be open when the hot water fill is selected.
Scan and upload it here. Or take a photo of it with your Apple or Android phone and upload it here.
RD427
NY
Please see the attached jpeg image of the washer schematic.
Ok thanks,
Very simple, the T(tan wire) is cold, the V(violet wire) is hot. Both use the same WR(white/red wire) for neutral.
Take a voltage reading at the COLD side solenoid when you have it set on HOT, and see if your meter reads 120 volts.
No.
RD427
NY
Sorry for delay in response!
Reading on the cold side solenoid reads approximately 120vac when hot is selected.
does this mean the relay needs replacing?
OK, then the problem is the TEMP SWITCH SELECTOR, But Since you already replaced that TEMP SWITCH SELECTOR, its sounds like You have your TEMP SWITCH SELECTOR wires on wrong.
ORANGE/BLACK goes on terminal 1
VIOLET goes on terminal 2
GRAY goes on terminals 3 and 4.
RD427
NY
I checked to connections on the temp select switch. All connections are as you indicated.
Any other possibilities?
I truly appreciate your help!!
Then I really don't know, you shouldn't be getting any cold if hot is selected. You've replaced all the parts that relate to this problem.
I'm puzzled too.
