WM3370HWA/01 dE door lock error
djbrowne
Fontana CA
WM3370HWA
LG
Getting the dE door lock error. Already installed new door lock and it didn't fix it. Replaced control board and still didn't fix it? What else could it be?
Added complete model number
WM3370HWA
Missing some digits, I found WM3370HWA/00 & WM3370HWA/01.
Total guess!......is the door hook ok?
LINK>
Locker, hook
dE
Door is open error
Check/Repair
Unplug the washer. Check the door for an obstruction. If the door is damaged, replace any defective parts. If the door is closing properly, check the door lock/switch assembly wiring. If the wiring connections are sound, replace the door lock/switch assembly.
Above is all I could find.
How was the wiring?
The door hook was ok?
Check each and every wire one at a time....maybe an off balanced load allowed the basket to bang into the harness.
