- WM3670HRA
- LG
- 1-5 years
LG front loader model WM3670HRA, awful sound coming From bottom when draining, so I changed the drain pump impeller part 4681EA2001T, started the washer back up, humming sound at the beginning of cycle, went into wash, then no draining and got the oe error, so I check the drain hose in the back took off front panel again and checked underneath again (also I forgot to mention the screw out filter thing I take out and clean it as needed, and when I unscrew that all the water empties from the washer freely) I poured water in the drain hose and water poured out freely to the bottom where I unhooked it from the drain pump. So it seems the big hose underneath coming from the barrel and the drain hose are not clogged. What else would it be?
