WM3770HWA LG Washer Door Leak and Hinge Adjust
Contsi
MA
WM3770HWA
LG
For a few months having a leak at the bottom of the door (rubber seal looks ok)
Now the Plastic trim on inside of the door that covers the hinges is scrapping against the
screw head for the hinges, like the door sagged. There is also more resistance when closing the door,
Is there an adjustment for the hinges? Attached file show the chipped plastic from the scrape.
Thanks for any help.
I changed on your original posting.
None that I am aware of.
Usually means it needs:
LINK> Hinge assembly
Also inspect the door frame pieces are that can also crack/break at the same time.
